TwinTurbo.NET: Nissan 300ZX forum - I used to run those turns.
Subject I used to run those turns.
Posted by Woody75 (Denver) on August 04, 2013 at 10:07 PM
  This message has been viewed 190 times.
In Reply To Ash Massive Intercooler side marker modification help posted by SMAZ (OKC) on August 04, 2013 at 12:08 PM
Message What I had to do with my Stillens was remove the rear bulb completely, remove the lip on the housing as well and tape over the hole. That bulb is just a marker light. The front bulb is a marker and turn signal. My Stillen IC ducts also had holes in them for more room for the signals. Doesn't appear the Ash's do so not sure if it will work still.
With the stockers you could do the standard move/redesign for the main bulb. Cut off the rear bulb, tape over the hole. remove the main bulb and redrill a mounting holed on the side of the housing.
JackB nimble JackB quick JackB can suck my dick =P - james-lee 11/02/01
Arrogance is the #1 weapon against Supra Owners - MikeH 08/06/02
Dallas with a Z: I like the bulge dude 05/02/03
Bezbefootball: Does dick have anything for me? 10/21/03
